← Back to AFE-E630
AFE-E630 GPIO
Test​
Export GPIO then you can use control GPIO from userr space through sysfs.
Export GPIO0
# echo 8 > /sys/class/gpio/export
Set GPIO direction to in/out
# echo "out" > /sys/class/gpio/gpio8/direction
Set GPIO value 0/1 if GPIO pin define is output
#  echo 1 > /sys/class/gpio/gpio8/value
Unexport GPIO0
# echo 8 > /sys/class/gpio/unexport
GPIO Test​
  1. GPIO0 and GPIO1 are taken as an example: Connect GPIO0 and GPIO1
  • Export GPIO0 and GPIO1
# echo 98 > /sys/class/gpio/export
  • Set GPIO0 to output and GPIO1 to input
# echo "in" > /sys/class/gpio/gpio98/direction
  • Change GPIO0 to 1 and read GPIO1 value
# cat /sys/class/gpio/gpio98/value
1
  • Change GPIO0 to 0 and read GPIO1 value
# echo 0 > /sys/class/gpio/gpio8/value
0
2. Test GPIO mode 2(Short Pin1->6、2->7、3->4)
# /tools/test/adv/gpio/gpio_autotest.sh
