← Back to AFE-E630
AFE-E630 Linux update CAN FW
Contents​
  • 1Prepare 1.1New Firmware 1.2Tool 1.3Firmware in DUT
  • 2Enter Upgrade Mode 2.1Stop slcan driver 2.2Get Can port 2.3Swith MCU to IAP mode 2.4Reboot DUT
  • 3Upgrade Firmware 3.1Check IAP Mode 3.2Upgrade Firmware 3.3Reboot DUT
  • 4Check Firmware
Prepare
For Upgrade firmware, A tool named usb-flash and a new firmware are needed.
New Firmware​
Ask PM for help to get the latest firmware like SLCAN-FD0V0102.bin .
Tool​
usb-flash is integrated by default in version 20250408 or later.
Check usb-flash :
# usb-flash -v
Advantech HID IAP Console v0.1
For early versions, download the tool from here : usb-flash
And unzip usb-flash to /usr/local/bin/ on DUT.
# tar -zxvf usb-flash.tar.gz -C /usr/local/bin/
# chmod +x /usr/local/bin/usb-flash
Firmware in DUT​
Check firmware version in DUT, taking can0 for example:
# /tools/test/adv/can/can_get_firmware_version.sh can0
[ OK ]: can0 Firmware Version : 0102
CAUTION
Firmware upgrades are only supported in V0102 or later versions
Enter Upgrade Mode
Stop slcan driver​
# pkill slcanfd
Get Can port​
Get can port ttyACMx (x=0、1、2...)
# dmesg | grep slcan
[ 6.880193] can0: slcan on ttyACM0.
[ 6.890344] can1: slcan on ttyACM1.
Swith MCU to IAP mode​
# usb-flash -s /dev/ttyACM0
# usb-flash -s /dev/ttyACM1
# usb-flash -s /dev/ttyACM2
Reboot DUT​
Reboot DUT for MCU to enter IAP mode.
# reboot
Upgrade Firmware
Check IAP Mode​
Check whether MCU is in IAP mode.If there are nodes hirawx (x=0、1、2...) , MCU is in IAP mode.
# ls /dev/hidraw* -al
crw------- 1 root root 235, 0 Apr 8 05:56 /dev/hidraw0
crw------- 1 root root 235, 1 Apr 8 05:56 /dev/hidraw1
Upgrade Firmware​
Taking SLCAN-FD0V0102.bin as an example of the file name of the latest firmware.
Suppose SLCAN-FD0V0102.bin is located in the root folder of the USB flash disk.
Adjust SLCAN-FD0V0102.bin and /run/media/sda1/SLCAN-FD0V0102.bin according to your actual situation.
# cp /run/media/sda1/SLCAN-FD0V0102.bin ./
# usb-flash -f SLCAN-FD0V0102.bin
Enter Y for each can to start upgrade process.
Do you want to update firmware on this device? (Y/N)Y
[==================================================] 100 %
/dev/hidraw1 update successful
/dev/hidraw0 update successful
Caution
DO NOT cancel the process of upgrade while upgrade is going.
DO NOT power off DUT while upgrade is going.
Reboot DUT​
Reboot DUT for MCU to enter normal mode.
# reboot
Check Firmware
Check if the firmware has been updated successfully, taking can0 for example:
